CAN I OVERCLOCK MY VENGEANCE 1600 MHZ TO 2133 MHZ (I HAVE GOOD AIRFLOW IN MY CASE )?????
I DON'T KNOW CAN YOU? DID YOU TRY BEFORE YOU POSTED ON THE FORUM? EVERY HARDWARE IS DIFFERENT!
IT'S RAM AIRFLOW IS IRRELEVANT BUT I PROMISE YOU IT WON'T BE STABLE.
YOU GOT TO HAVE ENOUGH KNOWLEDGE ON WHAT VOLTAGE AND TIMING TO USE BEFORE YOU START BLASTING OFF TO YOUR GOAL. TOO MUCH VOLTAGE WILL CAUSE OVERHEAT AND WILL REDUCE THE LIFE OF A MODULE. NOT ENOUGH VOLTAGE WILL SEE YOU WITH CONSTANT CRASHES. EVEN INCORRECT TIMINGS WILL CAUSE THE OS TO CRASH.
And yeah, is you capslock broken?
thanks guys . than best idea is to oc it to 1866 ? AND NO MY CAPSLOCK IS NOT BROKEN !!!
Just start off to there (1866) and once you're sure that you can keep it stable on that frequency, you can bump up to 2133.
