so got a new mobo and cpu fm2a88x extreme 4 with 8500k, i have never used amd and im trying to use core temp and it doesnt work i have everything in the bios factory and it reads 0c i have googled and seen this looks to be common with amd..... so is there a better program to use?? i like to have the temp in the task bar since i have it clocked at 4.6 and would like to know temps HW monitor shows nothing over 66c while gaming but im so use to core temp i would like to use it and advice or help would be awesome
Core Temp works fine on ny FX 8350. You could give speed fan a shot or motherboard monitor.
yea i have never had a problem with it either :/ i will give them two a shot
I stopped using CoreTemp years ago. CPUID HWMonitor all the way.
are any of those able to be ran in the task bar?
speed fan works looks acurate, guess i will use it thanks guys
