I know that NAS is a pretty awesome solution for storage, well I was wondering, would there be any issue in removing drives from my existing computer and placing them into a NAS enclosure, I'll be doing this at some point, regardless, simply due to the fact that I'll be upgrading my setup within the next couple of months, I plan on going to a mini ITX build. I'll even make a PC Part Picker list if any of you are interested?
Either way, I plan to upgrade just about everything other than my storage and graphics card, I'll also be keeping my peripherals for some time, as they're fine for now, however I should consider upgrading my keyboard more than anything out of my peripherals, simply because it's a bit funny every once in a while, some keys don't work on the first press, etc.
But to get back to the point, when I upgrade my system, I'll be placing my 3.5" HDD's into a NAS enclosure, and then my system will probably run off of 2 x SSD's, maybe 2 x 500GB SSD's, simply because I don't need a TONNE of storage in my system, I could even consider a M.2, but maybe that will be an upgrade for another date. I simply wanted to know, that if you place drives into a NAS enclosure, do they automatically get assigned different drive letters? Or do they no longer keep partitions, etc? - I'm not 100% sure on how NAS works down the the detail, I mean I know enough to know that it'll be good enough to store a lot of data and maybe run some less demanding games, etc.
Also, would you guys say it's a good idea to install compilers on my NAS solution or not? - I'd also like to mention, I don't think I'll need to get WD Red drives as I won't be leaving my NAS on 24/7, I'll only be turning it on when I wan to make use o my PC, even then, if I'm doing some basic stuff, then I guess I won't need my NAS at all, so sometimes I won't be using my NAS solution at all.
My final question, can you hook your NAS solution directly to your PC, i.e. via Ethernet or USB 3.0? - If so then that's great, I plan on trying to get some pretty good performance out of my NAS enclosure, if not then I don't mind using a wireless solution, but I'd assume that you can connect it directly to the PC? If so, I may also want to consider investing into a really small networking switch, just so I have enough ports available, as I currently connect my PC to my router by using a wired connection.
