Continuous beeping when turned on
searched for this but found nothing
just got my computer from the shop (i was gunna build it but these guys got me a better price on the parts and would give me a warranty if they built it so i let them do it.
just set it up and now it beeps... alot. i know this is a proccesser problem but could you tell me any common problems that could cause this. worse comes to worse I'l just give it back to the shop tomorrow.
 thanks in advance.
Dan
The RAM is not properly installed. I had the same problem with my build. Just push the sticks in.
I too have the same problem with my build. how on earth could you not put the sticks in correctly though? Could it possibly be compatability issues?
might not be in all the way....
Yeah, sounds exactly like a RAM problem. Take them out and put them back in, maybe try putting them in a different order. I've had this problem before a few times. Also make sure that the clips are snug against the sticks, be assertive, but not overly assertive and wait for a dim click sound.
I cannot get it to stop beeping!!! would this be ram compatability issues???
