Console/Terminal for J2SE 1.4?
Hey does anyone know how to get user input from a keyboard in Java J2SE 1.4?
In later versions I can use Scanner, but that’s not an option in this version.
Managed to get something working!
Credits to @Engle
Post in the lounge:
https://forum.level1techs.com/t/the-lounge-one-more-for-the-road-edition/166891/390?u=derbshey
Here’s the code I’m using right now:
import java.io.BufferedReader;
import java.io.InputStreamReader;
public class Main2
    public static void main (String [] args)
        BufferedReader bR = new BufferedReader(new InputStreamReader(System.in));
        int pL = 0;
        String Test = "";
        System.out.println("Enter the password length. ");
        try
            Test = bR.readLine();
        catch (Exception e)
        pL = Integer.parseInt(Test);
        System.out.println("The password length you entered is: " + pL);
Kind of a tricky one because you have to use two imports instead of one.
Regardless, it works.
That was the oldschool way to do it. I still use that method today. Last time I used scanner about 6 years ago, it would frek out with some utf-8 inputs. I asume that is fixed but I would rather deal with raw streams.
