Hello, everyone!
I need your help. I’m trying to connect to a remote computer via VNC, but I get the following message “Connection was refused by the computer” Could you please tell me what this could be due to and how to fix this error?
I will be very grateful for your help!
Hi, I know two possible reasons for this error:
- VNC is not working on the specified port range. The standard VNC port is 5900. Make sure that your VNC server is configured to use this port.
- The VNC server is not running. Make sure you log in with the correct user/password combination.
There may be other reasons, you can read more here: https://www.helpwire.app/blog/vnc-viewer-not-connecting/
I hope my answer helps you!
Is the firewall allowing that port?
