Connecting a Linux Hyper-V guest to its host using an internal switch
End goal: I’d like to transfer files from the Linux (Mint) guest to the Windows host over FTP.
I changed the adapter settings in both, but am unable to ping between them, even though they’re on the same network (192.168.15.x)
Am I missing something?
Might be the Windows Firewall on the host blocking inbound ICMP ping. Start with disabling firewall on the host just long enough to test it again.
If it still fails post the output of these commands
Windows Host (run these from powershell):
Get-VMNetworkAdapter -All
ipconfig /all
Mint:
ip addr
I both love and hate when answers are this simple. I was able to ping Linux from Windows, but not the other way around. (Although interestingly, enabling ICMP in Windows firewall did not fix this?)
I wasn’t able to get FTP to work, but using WinSCP and OpenSSH-server proved to be a great combo.
It’s likely an issue with either the scope or the rule just isn’t enabled for Internal Switch’s profile (set to public?). But this is actually ideal. Keep the guest firewalled off from the host unless there is a need otherwise.
Glad to hear. I assume this means your host is now pulling the files from the guest over SCP. Ideally this is how all file transfers should flow. If possible, always make the host the client and pull from the guest so you don’t expose ports or services to the guest.
