Confused Between AMD ryzen 5 2600 and 2600?
Which Is the best One To choose for desktop processor. i am looking for best for both the world (GAming & Work ).
My gutt feeling goes for 2600x . what about you guys
2600 ryzen
Check Price Here -
2600x Ryzen
check price here -
quick
Same CPU but the 2600x has a slightly higher base clock, 4.2ghz on max boost vs. 3.9ghz from the 2600 “non-X”.
If you know how to overclock you can get the 2600 to match the 2600x.
It is generally not worth it for a mild clock uptick that you can get by overclocking. You are looking a only a few frames difference even without the overclock.
