hi dear community
i have a problem and i have a small question
i add an interface to the public zone in my RHEL server from network manager
but when i try to add it from firewalld it shows me an error message that the interface is under control of network manager
i have no experience with firewalld and i’m hoping for your help
These aren’t tools I use, but have you checked that your rules are being applied? for example with ‘iptables -L -v’
Firewalld and Network Manager will be talking to eachother via dbus, you may not need to do anything
try to reload and then check
What version of RHEL?
iptables s blocked by default
i did and it shows a long error message
i’m using the latest version 8.1 with the latest update
@nx2l i got this error message
what services are running/enabled?
i have firewalld and network manager
i deleted the connection where there is the issue restarted and configured again and it works well now
it looks like there were a conflict between firewalld and network manager over the zone where the interface should belong
thank you so much my friend for your support
