Fortnight was said before pubg bet they are mad
Hah thats a cool vrm.
My eyes are littlebit too tired to count the exact numer of phases on the Vcore vrm there.
Calling it now Mobos 1K +
Definitely
Prob needs a dedicated circuit to make sure you house doesn’t burn down
32 Phases or so?
more than 1 phase per core
Lol yeah assumming that the particular cpu has a FIVR and no igpu?
My eyes are a littlebit too tired to count, hard to see the end part with all the lighting.
Mechanical keyboard ready WTF?
Cooling solution looks like the Hades Canyon NUC on steroids
32 Core threadripper confirmed in Q3
https://www.anandtech.com/show/12906/amd-reveals-threadripper-2-up-to-32-cores-250w-x399-refresh
The Asus AIO’s look interesting, Another Asetek OEM at heart but I think the VRM/Component cooler fans on the RYUJIN 240/360 CPU block are a neat idea if, they function as theorized, and can fit. Man that thing is enormous.
Going to be a bitch to get that running on almost any chip. I bet it’s rated for a single board and a binned 8700k (maybe 7700k). Super stressful on the IMC.
If you thought your Trident Z RGB didn’t have enough bling and champagne sparkle… worry no more.
The “Trident Z Royal RGB” series is here, for those dawgs that want the full bling bling and ice cubes with their premium champagne:
Anyone knows if that GPU is a real product or just a showcase thing?
I think that may be the point of RGB ![]()
LN2 loop? You mean der8auer’s thing? That’s not LN2 and it’s also supposed to be similarly priced to current CLCs.
They sell them as limited editions, a few thousand cases produced or so.
Except they are already ahead of Intel in terms of PCIe lanes on Ryzen? AFAIK Intel doesn’t have a dedicated 4 lanes into the CPU, they do everything via chipset.
Yeah I was surprised someone finally did that, I mean it’s always talked about that the VRMs are a bit on the bad side if you’re using a CLC, why noone else thought of that is beyond me. There was a DeepCool(?) CLC a while ago but that fan just looked like it had been taped on. Wonder the noiselevel though.
That actually looks kinda cool, can’t you swap out the plastic on the regular tridents though? If not they should be… like Gigabyte does on their boards.
What GPU? That GPU?
You mean the Radeon 295X2? Came out somewhere with the 200 series… A bit after that. And IF CF works - it was beating everything. But it was AMD, so nobody cared.
That and that you basically needed your own power plant to run it ![]()
Also that LD03… Am I the only one that finds it stupid that an mITX case is that huge? Like… what’s the point of mITX then except letting the prices go through the roof …
Ah, thanks. I didn’t think they would fit an old card into their new case.
