i'm posting this in the inbox.exe because it is very important to me and that it be answered and solved.
i am trying to sell my computer to buy the rest of my future build. in order to do so i need everything in working order. i also would like to do so very soon.
someone i talked to said my motherboard might be fried, so thats where i got that piece of info.
my build is this,
EVGA Geforce GTX 560 Ti
Intel Core 2 Quad Q6600
Intel ATX LGA775 D975XBX2 Motherboard
4GB DDR2 silverline Mushkin RAM 800 Mhz
630W RaidMax power supply
1 250gb wd black, 1 140gb seagate barracuda
my moniter is a acer al2016w with dvi
so for a long while 2-3 months my computer had no case and still dosen't have one. i was on vacation and didnt have my case with me with i set it up without. so anyway it worked 100% fine yada yada yada when i was on vacation, but when i brought it back home i found out the case had been moved to storage so i couldnt get it and decided to just set it up like i had before on a table, parts all out in the open. i proceded to turn it on by using a piece of metal to touch both red power pins on the mobo. everything worked fine except nothing showed up on screen except "no signal". i left it on for a while to see if something would happen but nothing did so eventually i just turned my computer off via the power switch on my psu. ive tried this several times including using a hd 4850. eventually i gave up obviously. one more thing that i noticed is that when i had it only for awhile the fan speed never died down either.
so what do i do.
can't think of anything else to say
gracias
