I just put the parts together and hooked up everything but it just will not start?
are white wires negative and red positive? (the power switch wires)
Could it be that the power supply just doesn't work?
make sure everything is connected properly. there's also a switch on the power supply. did you plug in the extra 4 pin power to the mother board? did you connect power to your graphics card?(if you have one)
what do you mean extra 4 pin? and i did flip the power supply's switch
might even be an 8 or 6 pin. depends.
I already have them connected and it was a 4 pin
Do any LED's light up on the motherboard? The way you connect the power switch doesn't matter, as long as its on the right pins since it just creates a short between the pins.
i dont even think there is an LED on the motherboard
http://www.overclock.net/t/96712/how-to-jump-start-a-power-supply-psu-test-a-power-supply-and-components
unplug it and take it out, then jump the power supply. this will test to see if it will even work.
power supply works, just jump started it
~bump~
unplug all the sata drives and only plug in power to the motherboard/graphics card.
the power supply works doe. I think it is the motherboard.. I'm returning this cheapo board
