can you guys give me parts for a 200-600 dollar build with windows 7 home premium? i'm looking to use it for work and school mostly but some gaming and photo editing. Just need the best bang for the buck.
This should be in Build a PC but I will not turn down a cry for help!
http://pcpartpicker.com/p/29rwe
You could fit in a higher end GPU (nothing wrong with the one included) if you choose to pirate windows but that is completely up to you and depends on how you feel about pirating.
Any questions?
Here is one: http://pcpartpicker.com/p/29sag
Slightly better GPU and what I believe to be a better motherboard. Its 12 dollars over but hey, whatcha gunna do.
Moved :)
Ill also delete the other post.
Jut try post it in the correct place next time
thanks guys
