Okay, my last post was confusing. But let me tell you everything about the PC I would like, and about me.
1. I'm Canadian
2. Budget: 800$ CAD
3. Newegg doesn't work for me, so If you are going to post suggestions, they need to be from another site. (Sorry!)
4. This PC should be highly upgradeable. I would like an awesome CPU, one that won't bottleneck from an insane GPU (should I upgrade in the future.
5. Also, the motherboard should be upgradeable (lots of slots, etc)
6. FInally, the PC should be good for overclocking
P.S SInce I'll be planning to upgrade, I don't need to play BF3 on max settings. Medium graphics for any game is fine, as well as a good frame rate.
Sorry I'll have to postpone the build I slept in and only had time to do one build before work, I'll be back in about 8 hours
Not to worry man! I wasn't talking about you, mostly other people replying to my post didn't understand, so I thought I would specify. Take your time.
so Newegg.CA won't work, they have a canadian branch
Very awesome! This is just great. Don't worry about been a couple dollars over budget.
Never mind on the overclocking. I might later but for now, I have no need for it. I'm sorry about being such a noob when it comes to computers. I'm just making the jump from Xbox to PC.
well if your not worried about overclocking you could get a 7850 this xfx after rebates is 160 http://www.newegg.ca/Product/Product.aspx?Item=N82E16814150617
it'll put you a little over. And just save an aftermarket heatsink till later.
http://pcpartpicker.com/p/jYOh Exactly 800.88! :D
That seems about as solid as it gets for 800
So would you recommend it?
