Computer for light loads and longevity,
So, my fathers pc is starting to give up (All files are safe, Phew...), He is looking for a smaller size build which is on the silent side of the spectrum. But really the key here is for it to last, a simple pc for a long time forward.
¤Budget is somewhere around 500-600$
¤Living is Sweden although currency any such is a smaller problem mostly need input on the system(Tips and Hints).
¤There idea is to buy it from a Swedish site (www.inet.se)
¤No peripherals are needed.
¤The computer is intended for office work(and will be located in a home office), no hard graphics.
¤No over-clocking, he will have to stick to stock clocks.
¤No operating system required.
http://pcpartpicker.com/p/7T2fQ7
My thoughts, The chassis is a smaller model with some sound dampening, also the ports are located forward, which is good since it will be located under a desk.
The motherboard seems like a good alternative with enough connections, and build quality(also the fan control in bios seems good)
The powersupply is semi-modular and Gold certified with a semi passive fancontrol, Also from what i have understood from reviews the quality is solid.
I have excluded GPU since i have a GTX460 he can have which should be more than enough, if he need graphics performance, Do you guys think he will need something else than the intel stock fan? is there any cheap ones that will fit this case and offer worthy performance(sound and cooling) for a reasonable price?
Thanks in advance, also he has hard drives not sure if he has a SSD, Would you prefer M.2 over Sata6 in this application? Is 16GB ram overkill, same with PSU?
I'm grateful for your thoughts and opinions!
M.2 isn't instantly faster than SATA drives, it's more that you're using PCI-e SSDs which the average person really doesn't need
Otherwise it looks fine overall unless you really need USB 3.1 then you'd be fine on a less expensive haswell build
You could also probably get away with 8gbs of RAM
Thanks for the input, yeah perhaps 8gbs is enough, he might aswell go with the stock cpu cooler for starters,
http://pcpartpicker.com/parts/partlist/
I would get the largest SSD that your budget allows. 8gb is plenty and getting a single stick makes it easy to upgrade. The PSU is too large and you will lose efficiency, a smaller gold rated one will be a better option. To be honest if the motherboard provides the outputs that are needed you probably don't even need a GPU.
i5 6400 with an R9 380:
http://pcpartpicker.com/p/7QzgGX
PC for light loads? Non gaming? What is he doing with it? Why are people throwing out gaming spec PCs?
If this is going to be a PC for browsing the web, just build a cheap $100~$150 PC.
Here's my cheapo PC I built for under $100. lol
Specs:
Celeron G1820 2.7ghz $25
2x4GB SO-DIMM DDR3 1333mhz $0
Asus H81T/CSM Mobo $45
BESTEK 90W laptop charger $8
Bitfenix Spectre 140mm fan $10
160GB 2.5in Mechanical storage $0
For streaming netflix/Hulu/Amazon videos/etc. and for light gaming. Torchlight 2, Dragon Throne, etc.
thats creative but you should repurpose a cereal box for the case. that would be awesome
Actually, I'm planning on making a DIY case that looks like a PSU. That's why I got the 140mm fan.
Sorry for going off topic...
make a new thread with pics because those are cool
I like the arctic cooling alpine 11 pro for a quiet inexpensive better-than-stock heatsink.
