my laptop (Lenovo IdeaPad L340-15IRH Gaming) ethernet port died. Out of warranty. I have good soldering skills and I want to replace the faulty ethernet port. Can you help me with list of HW compatible & size compatible ethernet ports? Motherboard: lnvnb161216
USB external ethernet is out of question (low on USB ports).
How do you know the port itself failed and not any of the supporting hardware for it such as the controller chip or some capacitor or resistor on the board surrounding the controller?
I still see Realtek GbE controller in device manager after I uninstalled it. I tested lan cable, which works. Eth led is not responsive.
Which is pointing to dead eth port.
Thats a hard one because there is no specific part list for everything on the MB available outside Lenovo and the port itself is a bit different than typical ports. Youll likely have to open the laptop up and remove the port and see if you can find any model listed on it.
I use some cheap USB → 1Gbit Ethernet NIC for my laptop (which didn’t have any ports to begin with, like most modern laptops). I’ve seen some 2.5G/10G USB NICs as well but these things can get expensive really quick.
1G USB NIC to carry around in my laptop bag is what works for me. Got asked once if I’m a hacker and why I need a cable
I’ve repaired faulty Ethernet ports in the past, the physical port is almost certainly not the problem, but the controller. Being present in device manager, even without errors, does not mean the device is functioning properly, only that it has failed in a way that it cannot report / the os cannot detect.
The only real way to find out what part you need is to disassemble the laptop and physically look for it. You should have good luck following traces from the Ethernet port back to the first qfn or bga chip that says realtek on it.
I know laptops often run out of USB ports for things given their size, but I think the easiest way to fix this is to get a USB-C hub that breaks out to a couple extra USB ports and an ethernet port on it.
Example:
No it wont be the best bandwidth or lowest latency network connection, but you are already making a lot of compromises for gaming and other best performing things just being on a laptop so the extra couple milliseconds latency shouldnt be an issue.
The Ethernet port is likely broken since its light won’t turn on, even though the cable works. You can try reinstalling drivers, checking BIOS, or testing with Linux. If that doesn’t help, the port needs to be replaced.
But what exactly is damaged… is the port physically damaged? Because if it’s not physical damage or a problem with the soldering, it will be more likely a problem with the chip or the board.
As you were told on electro-tech-online, this is one of those specific ports, it may be difficult to buy something similar somewhere. Alternatively, look for a cheap damaged motherboard for parts.
