Im looking for a graphics card that will work with the AMD FX-8350, and im kind of a noob, and i want to know if a GeForce GTX 660ti is compatable with that processor. In short, I dont know if an EVGA card will be compatable with an AMD processor.
All GTX and HD cards are compatiable with all FX, i3, i5, i7 processors. I would suggest you grab a 7870 instead of the Nvidia card so you can take advantage of the AMD ecosystem with Catalyst. It will allow you to overclock your CPU and GPU in windows.
Yes they work together.
