After watching the build your own gaming headset video I bought a zalman zm. While playing around with it I found it to sound much better while holding it close to my mouth rather than on the cable so I decided to make something to hold it on my headphones like a headset. On the superlux HD668B you can just wrap the wire around the thick metal frame to hold it up. On the end is some paper rolled around the end and super-glued to the wire to give the zalman something to hold onto.
Wont you have that extra cable hanging out in front of you now? Or did you secure it to the headphone cable?
Also cool lifehack
Thanks. That's a good point, at the moment I just have it hanging, but it can certainly be secured somewhere on the headphones or cable. I wanted it to be removable since I don't use the microphone very much.
