Cloud Storage vs NAS for Business Operations
Hello Tech Geniuses,
I would like some advice regarding file storage solutions for business operations. We are a small business (not in the tech sector) with a limited budget. However, we do generate files that I need to keep around. Would it be acceptable to rely solely on Google Drive? I have a feeling that a NAS that backups to the cloud would be ideal, but I’m not sure if other companies only rely on cloud storage. How does Level1Techs’ handle their business files? And just to confirm, best practice is to not have employees save files on their computers, only to a NAS or cloud drive?
Thanks for the insight in advance!
To my knowledge, all cloud providers state, that the customer is responsible to backup his files. So in any case you need to store your data somewhere on your site.
Depending on the data`s value, more than 2 sites may be a good idea.
Basically, you need to apply the 3-2-1 rule;
  • keep at least 3 copies of your data,
  • in at least 2 forms of medium (optical disk, magnetic disk, SSD) and
  • at least one copy stored offsite.
Despite being seen as ancient by (post-) millennials, optical data storage has the benefit it can be restored from a known safe state. Pretty useful if some hacker messed up your storage pool (encryption!). Blu-ray disks have a relatively high capacity (at worst “just” 25GB, more likely 50-100GB per disk, don’t tell me you have data sets larger then that who can’t be split over multiple disks :floppy_disk: ). Your company needs to have a policy storing static and dynamic data, the former is very suitable for storage on BR disks.
I do recommend a CMS (content management system) for data operated on by multiple users at the same time. It often has backup tools as part of the package.
As for hardware, a NAS is a good start. Consider a 2-tier storage solution: fast NVMe-based for hot data (projects being actively worked on) and a slower ‘cold-spare’ NAS with slower but high capacity HDD’s for finished projects and/or other static data. Neither have to cost much: an older workstation (Dell, HP, Lenovo, etc) with Gbit or better NIC and a PCIe to quad NVMe adapter card suffices for the “hot” NAS (1 TB NVMe drives are still fairly cheap although prices are rising again, unfortunately). Those NVMe drives are to be kept in RAID5 or 6 for redundancy. Mind, any RAID solution with a zero (0) in it is a data-loss disaster waiting to happen. Ask Linus (<- YT-link!) :stuck_out_tongue:
The “cold storage” NAS can be as simple as another old (but large) workstation with lots of space for 3,5" drives and an HBA (host-bus-adapter), stuffed with 16TB HDD’s. Again, RAID5 or 6 to keep your chances of recovery in case of drive failures alive :stuck_out_tongue: If possible, equip this unit with an NVMe cache for the array, an adapter with 2 NVMe’s in RAID1 will do fine here.
Do mind both NAS’s need to have a UPS (uninterruptible power supply) to keep data integrity in case of a power failure. If the UPS is big enough, both can be on the same unit (it’s probably cheaper too :wink: )
HTH!
Thank you for the response! Can you expand on the concept of a CMS for multiple users? What happens if two users are editing the same file at the same time?
I’m familiar with TrueNAS Scale, as I use it at the home. Could I use two TrueNAS Scale systems at different offices that sync to each other? Do I just setup a network drive for the users to store files in? Is this how they do it as LMG or do they store files directly in the cloud too?
Do you have any recommendations for a budget chassis for a NAS? I’m thinking of a 12 bay chassis. Should I be looking into a used SuperMicro 12 bay server?
Thank you for your time!
That’s what you configure in the CMS policies.
That’s the basic premises of Network Attached Storage, yes. And yes, that’s how they did it at LMG back then, I’m aware the responsibility for their networking has shifted from Linus to others in the past few years and I reckon they have much less janky ideas on how to set up proper networking at LMG :wink:
I don’t use TrueNAS so can’t tell you anything about it.
SuperMicro is, by and large, quality stuff so it’s a good choice. But there’s more then just SM and I’d be hesitant to invest much, at least initially getting to know the systems involved, so maybe try something smaller/simpler/cheaper to get your bearings around this stuff. Like the aforementioned old workstation. Especially as a proper server chassis is gonna be LOUD :scream_cat:
Can’t speak to server form factors, but if you want something in normal ATX desktop format, the Fractal define 7 XL is pretty much the gold standard for making a NAS box (unless going for small form factor). I have the non-xl as my gaming pc, and I kinda wish I had just built my NAS in it instead of the hand-me-down. But I decided I wanted the gaming PC in the new case for possible addition of AIO water cooling which the old case can’t support.
Thanks for the response! This seems like a good option. However, I do need something that is rack mountable.
Are you wanting an off the shelf solution or are you wanting to DIY? And how many U’s do you want?
I’m flexible, but I’m looking for something around 2 to 3 U. I’ve seen used Supermicro servers that are 2 U with 12 bays. Also, the HL15 looks nice, but the price is high. I’m comfortable with DIY.
I’d do some research then on what you current data needs are + projected future needs. What downtime is acceptable. Budget and then go from there. There are a lot of different solutions with both DIY and buying from an OEM and the support offered. IMO if your data is mission critical with a near 0 downtime being acceptable I would consider an OEM solution with a support contract.
From my professional experience on the OEM side 45drives(https://www.45drives.com/) and Dell(Products for Edge Computing | Dell USA) are both very solid options. Super Micro stuff is also really good, but I’ve had some issues with their customer service responding within the terms of the service contract.
If you decide on the DIY route I’d really consider going Epyc. Xeon isn’t bad, but I found it be overall more confusing than Epyc for purchasing/feature comparisons. For chassis, Super Micro, Sliger, and Silver stone all make decent chassis. Beyond that most other components from reputable vendors/companies tend to be good.
you must be lost…
Here’s an example of Google accidentally deleting a $135 BILLION retirement fund in Australia…don’t rely on others for your company’s data.
Setup a little NAS to back things up and move on.
We have NAS’s in production that backup dropbox, Google drive, EMR, accounting software, and a whole lot more.
NEVER trust “cloud” providers with your data since it’s just someone else’s computer.
I am by no means an expert, but I have been working toward building out the hardware i need to start a VPS hosting service, and maybe if that project can support itself financially, one day a data-center.
if you are willing to accept that most generic rack-mount cases are pretty trash, and super micros cases are very expensive.
silverstone has quite a few offerings. the silverstone rm41-506 4U, for example. has 4 internal 3.5" drive bays, and three 2.5" drive bays. and six 5.25" drive bays where you could install up to two FS305’s which hold five 3.5" drives each. or any other 5.25" bay to drive adapter.
that would bring your spinning rust up to a max of 14 spinning drives, at say 20tb you are looking at 280TB raw, ~250TB formatted depending on your redundancy configurations. throw in a couple sata SSDs for caching, and you have an absolutely baller file share. I haven’t run the numbers, but that may be sufficiently expensive that perhaps a 45drives storinator chassis would be worth looking into, but it is largely dependent on your businesses exact needs.
I must parrot what others have said though, if the data only exists in google drive, it is not safe, googles business support is just barely better than their consumer support.
For small businesses, using Google Drive or a cloud service like Microsoft OneDrive or Dropbox is an easy and budget-friendly option.
easy* and budget-friendly* option.
unless your business is large enough to justify the cost of the more expensive subscription for gsuite you end up with terrible data storage practices. since you can not edit shared drives only view in gsuite without the business standard subscription, so a bunch of data gets stored in the drive of whoever created the documents and it becomes a mess. and your data storage is limited to something like an aggregate of the 2TBs per user for their business standard subscription by default.
