Specs click here
Processor supported:
- 3rd Generation AMD Ryzen 9 3900 Desktop Processor, 3.1 GHz, (12 core / 24 thread)
- 3rd Generation AMD Ryzen 7 3700X Desktop Processor, 3.6 GHz, (8 core / 16 thread)
- 3rd Generation AMD Ryzen 5 3600 Desktop Processor, 3.6 GHz, (6 core / 12 thread)
Core Logic: AMD B450 Chipset
Memory:
- Supports Dual Channel DDR4
- Two 260Pin SODIMM sockets, support for DDR4 up to 3200MHz
- Expandable up to 64GB, depends on 8GB/16GB/32GB SODIMM module
Display: 15.6” Full HD (1920x1080) 144Hz IPS, 72% NTSC Display, Matte Finished
Graphics Processor: GeForce GTX 2070 GPU with 8GB GDDR6
- Support PCIe x16
- Real-Time Ray Tracing
- Battery Boost Technology
- Microsoft DirectX 12 Compatible
- Support 4 active displays
Storage:
- One changeable 2.5” 7.0mm(H) HDD/SSD, SATA interface
- M.2 2280 SSD, SATA / PCIe Gen3x4 interface
- M.2 2280 SSD PCIe Gen2x4 interface
Audio System:
- High Definition audio interface
- Built-in Array Microphone
- 2 Built-in Speakers
- Sound Blaster Cinema 6
I/O Ports:
1 HDMI output Port (with HDCP)
1 Mini DisplayPort 1.4 output Port
1 DisplayPort 1.4 over USB 3.2 Gen 2 (Type-C)
2 USB 3.2 Gen 2 Ports (Type A)
1 USB 2.0 Port (Type A)
1 2-in-1 Audio Jack (Headphone / Microphone)
1 Microphone Jack
1 RJ-45 LAN (10/100/1000Mbps)
Slots:
Micro SD Push-Push Card Reader
M.2 Card Slots
- WLAN Combo M.2 2230 Card with PCIe/USB interface
- SSD M.2 2280 Card with SATA / PCIe Gen3 x4 interface
- SSD M.2 2280 Card with PCIe Gen2x4 interface
Communication:
Built-in Gigabit Ethernet LAN
Intel Dual Band Wireless Wi-Fi 6 AX + Bluetooth, M.2 2230 interface
Power System:
Removable 6 cells Smart Lithium-Ion battery pack 62WH
Full Range AC-in 100~240V, 50~60Hz, 230W AC Adapter, DC output 19.5V, 11.8A
I’m conflicted whether I should spring for this one or not for two reasons:
It’s a B450 chipset, and from what I know on Ryzen 3 support, It’s a manufacturer by manufacturer basis. I don’t know if Clevo will do bios update support for this particular series of mobo.
It’s a Turing card, and I’m not a big fan of how neutered higher end of the series of cards are in mobile version counterparts, specially the Turing series of cards. This is not even accounting to the fact that AMD has shown it’s RDNA 2 to have better performance over the Turing rasterization and ray tracing wise at a better TDP which makes me wanna wait out on their mobile version.
With that being said, the price is so tempting…so…so…tempting. For those who are in the market for a laptop upgrade though and within their economical reasons should check this out.
