Cleaning up tech debt and diving into local AI
AI Disclosure:
I use AI for troubleshooting and want to learn to make my own small local models to test out some theories about uses for wildland fire behavior modeling. I haven’t done any agentic coding because I won’t trust an online model to have access to my computer, but I want to dabble a little with that with a local AI setup. I am very tentative about that, because I have fallen down a hole copying and pasting code into something I was trying to slam through on a short deadline and the AI added so much code I lost the ability to keep track and when I needed to debug something, I had too much code to realistically debug and ended up scaling back the project and starting over manually coding again.
I set up a NAS 2 winters ago and switched all my computers to various flavors of linux last winter. It’s all sorta patched together. My goal for this Devember is to clean up a bunch of tech debt, make sure I know how to do rollbacks and that is set up properly, and basically make my NAS as stable and boring as possible.
  1. NAS
    1. Move Unraid from USB to SSD
    2. Set up Immich, Geoserver, document tracking, something for git repo backups, and maybe Nextcloud or something like it
    3. Clean up audiobooks and music in Jellyfin or check out other options
    4. Serious data cleaning and organization to go through all the stuff I dumped on there from random hard drives
    5. Double check I actually have snapshots set up and have those instructions saved digitally and printed out
  2. Laptops
    1. Waiting to see if there are any super big wrinkles, then I’ll do a fresh Fedora 45 KDE install on my main laptop. It’s currently on 44, but after an update 2 weeks ago, it’s having issues. It could also be my failed attempt to set up hibernate 4 weeks ago….But it has also started going to the grub menu when I restart which it never used to do until that update. Being on a btrfs file system might be the issue? I am seeing that on a new Kubuntu install I just did as well and internet searches indicated it was because of btrfs. It also has some other freezing issues.
    2. Replace Bitwarden with something
    3. Wipe and reinstall Kubuntu on a backup laptop. It has the same issue with going to grub on start up that my Fedora laptop now has and the little amount of research I did indicated having the operating system on btrfs was the cause, but must look at more
  3. Local AI Rig
    1. Sourcing parts for a local AI rig. I snagged 2 R9700 before the prices shot up recently, but don’t have anything else. Hardware and building computers is definitely not my strong area so trying to learn about everything is really stressful.
    2. I’m definitely more on the software side of things, so I want to learn to make my own small models, especially dabbling in physics models modeling wind or fire spread. I realize ROCm is not ideal for that, so I’ll have to see how it goes.
    3. I just got laid off at the end of last week very unexpectedly, so a lot of stress between deciding if I should keep pushing forward building and learning local ai vs sell the gpus, but I’m hoping the skills learned will be worth finishing the system. With the recent downward trends in AI, I’m wondering if I should wait to see what prices do before continuing.
