Cisco power connector (5 V 4 Amps)
Does anyone know what this type of power connector is called and if there are any after market alternatives? I think I could frankenstein it from a PSU even but not sure if that is a good option.
What is that type of pin called, the one that isn’t square but rather like a “house”, same shape as on some of the ATX pins.
cisco
I suspect this is what you’re looking for - looks like that’s just a regular Molex Mini-Fit Jr connector.
Molex even makes off-the-shelf cable assembles for some of them:
https://www.mouser.com/ProductDetail/Molex/215328-1021?qs=DuoOggApuK%2BmUcHtq8Kv7w%3D%3D
You should obviously confirm the size/pin pitch first because they have other connectors that look very similar (Micro-Fit, etc), but that should get you started if you decide to just re-terminate another 5V power brick. :+1:
What model switch is that?
It’s an 819G router, comes with WWAN.
It very much does look like that one, thanks!
Fun note on this is that the connector is actually the same as the 2-pin in the 6+2pin GPU power connector. So you cut of the 2-pin and already have the cables attached and that can go with any generic power brick. It obviously risks sliding out as it does not hook in but works for me.
