Fairly new to Linux and decided to get a Rasp Pi 2 to monitor my IP camera feed and the weather on a older 720p monitor. All was fine until I did a reboot this morning now every time I try to launch Chromium it crashes and closes.
I have tried to uninstall and re-install to fix the problem along with various other things to no affect. When I try to run via console this is what it spits out at me.
Thanks in Advance for any help.
slo@pi:~$ sudo chromium-browser
[sudo] password for slo:
[1:1:0330/181731:FATAL:setuid_sandbox_client.cc(126)] Check failed: IsFileSystemAccessDenied().
0 0x000073d1b73a base::debug::StackTrace::StackTrace()
1 0x000073d2e5b2 logging::LogMessage::~LogMessage()
2 0x0000732ab2ae sandbox::SetuidSandboxClient::ChrootMe()
3 0x000075f3ff4c
4 0x000075cd7b92
5 0x000075cd806c
6 0x000075cd6e76 content::ContentMain()
7 0x000054d3b50c
8 0x00007238b772 _libcstart_main
Received signal 6
1 0x000073d1ba2c
2 0x00007239a230
3 0x00007238b9a6
4 0x00007239961e gsignal
5 0x00007239a312 abort
6 0x0000723c33ac IOfile_xsputn
[end of stack trace]
you absolutely do not need to use sudo
when launching a browser. In fact, you absolutely should not do that.
I encountered the same (almost) error with my chromium when I launched it with sudo
. When I didn't use sudo
, it worked fine.
Try it without sudo
sudo was just to produce the stack trace as I thought it would help in figuring out the root of the issue, a normal launch results in the following.
slo@pi:~$ chromium-browser
Segmentation fault (core dumped)
slo@pi:~$ [2372:2372:0330/210124:ERROR:sandbox_linux.cc(334)] InitializeSandbox() called with multiple threads in process gpu-process
Have you tried doing an update?
sudo apt-get update
sudo apt-get dist-upgrade
Can you give the output of the uname
with the -a
option appended?
Yes, I have done all the update using both the commands you listed above also uname returns, I hope that is what you needed.
Linux pi 4.1.13-v7+ #826 SMP PREEMPT Fri Nov 13 20:19:03 GMT 2015 armv7l armv7l armv7l GNU/Linux
Interesting. Is the package you're using called chromium-browser
or chromium
? From what I can see, both exist.
I don't have a pi with your distro, so I can't be 100% sure, but that's what it looks like.
