Choosing a Monitor
Wondering if anyone can help.
I’m looking for a gaming monitor to use for PS4 (currently) and for a PC (soon). The PC has a NVIDIA GeForce GTX 970 graphics card.
Two monitors I have in mind are the HP 24x 1080p 144Hz 1ms TN and Pixio PX247 1080p 144Hz 1ms IPS.
I currently spend most of my time playing Call of Duty, both Warzone and MP.
Thanks.
My go-to site for monitor reviews is usually rtings.com Their comparison tool is pretty nifty.
Thanks brother
I recently got an LG 27GL650F and I thorougly suggest it. It’s 144Hz GSync and Freesync compatible, IPS, “1ms response time” (if you’re willing to put up with inverse ghosting).
It’s good enough calibrated from the factory and it looks very good. It’s also not too expensive and allows for pixel response time setting while using adaptive sync which is something not all monitor have.
Thanks a lot man
