Choosing a fan controller
At the moment I am currently running 1 fan (as an front intake) in my new Corsair 350d due to the lack of fan headers on my motherboard, so I am ordering 3 corsair fans to fill the rest of the case, but am stuck between fan controllers. I have it down to the Bitfenix Recon or the NZXT Sentry 2. I like the touch screen capability and the automatic fan adjusting. Does anybody have a input or any better suggestions?
Thanks
If you want auto control and touchscreen the "Aqua Computer Aquaero" is considered the best.
If you want a simple thing that just works any controller from a reputable brand with enough wattage on each channel should work fine.
What motherboard are you using? Some motherboards come with a fan control utility.
Its some real crappy one that I pulled out of a spare hp desktop I had sitting around, there's no way it has any, but I think I'm going to go with the NZXT.
I'd stay away from the stupid touch screen gizmoz, they're a joke that just makes your computer look ridiculous.
NZXT Sentry Mix 2, NZXT Sentry Mesh, Sunbeamtech Rheosmart 6
