But I can't get very good fps in Chivalry. I never have been able to. I heard there are some fixes, but Steam Community seems to be down right now. Anyone else have this problem or know of a fix? Any help would be greatly appreciated! Thanks!
I play on the highest and 1920x1080, but that's only because even with everything on medium the frame rate doesn't change. Even if I put it on low, the FPS is barley better.
I can't even play it on the highest settings and im using a 7870ghz at 1080p. But i still get stuttery frames thats what you are probably confusing with low frame rartes. Maybe get fraps out and play like a game on high and see what frames you get.
The stuttery frames should be fixed in the next driver update. So they say.
