It’s really hard to tell with the spec the supplier is listing so it’s partially a buy at your own risk kinda deal.
IMO: this case would probably be better and it has list CPU cooler compatibility( * up to 153mm tall) so less guess work is involved. CX4170a | Sliger
Edit: Idk if it’s in your budget or not, but another good option would be something from silverstone(RM44 Height w/ expansion card retainer: 137mm, Height w/o expansion card retainer: 148mm)). but they can get even more pricey.
Yes, the Sliger and Silverstone are nice options. Unfortunately, they are double the price.
I like something like the Silverstone - with an upper bracket and PCIe retainers. However, the bracket in the Silverstone case does not go over the CPU. I was looking for some way to fix the CPU from both sides to lower the chance of movement (damage) during transportation. Any ideas about that?
Well it’s really pay for what you get kinda scenario. Pretty sure the Chenbro will be fine, but I’d personally go with the more substantive options, if this is going to be a long term build/use case(at least 5 years). Especially if you plan on transporting I’d be shocked if the sliger or silverstone don’t hold up better and/or their warranty coverage is better.
