Total Price: $338.71 (This price is converted to PH Peso to US Dollar)
This are the parts the are available in my country but some requested parts are not available. If you request parts i'll check it out if it's available. I added a DVI to VGA converter because my moniter use VGA connection. I can replace the processor with a INTEL CORE I3-4150 PROCESSOR but it will cost a total of $383.58, that is more than my limited budget. Thank You
depending on certain availabilities you may save money going with a R7 260x, which has similar if not better performance in some cases, but it takes more power and outputs more heat. also a different PSU maybe better (unsure of the one you have)
Just to let you know, your English is not bad. A few minor things here and there that aren't exactly perfect. But what I meant by change your GPU is say save up the money and get a 960 or 270x. Maybe 280/280x. A 270x is right around 160/180 USD.
Looks like a good build for the price, to me. You can always upgrade components later on and these parts will still give you better than console performance anyways. :)
Thanks, but this doesn't include a Memory (RAM) and an HDD but if you have a old pc you can use the HDD and Memory (if powerful enough). But you can always add a HDD and Memory if you want too.
upgrading you Pentium to an i3 CPU is not worth IMO, but upgrading to an i5 would be worth (only if you upgrade your GPU first) I'd suggest going with a r9 280 if you can get it for cheap.
