Cheap/used efficient medium-power systems for parents?
I’m trying to build medium-power “homelab” server for my parents that will also double as their desktop. However, I have never spec’d out something in this range before, or at this price, only high-powered desktops for much more. So, I would like your collective help in figuring out what I don’t know.
My parents currently have a desktop, but it’s an very old 2008-era system that is struggling with basic desktop usage. They will be retiring over the winter into a new house that necessitates having some servers running 24/7, and so I want to kill two birds with one stone by combining them. Here were my requirements going in:
  • Can handle light office, email, and occasionally watching live streams on a single 1080p monitor
  • Has enough power to handle about a dozen services running 24/7 in the background (I would like some headroom for future expansion).
  • One of the services will be intermittent transcoding (h.265 → h.264) of 2 video streams in real time (I would like some headroom for a 3rd, if possible)
  • Not powerful enough to consume that much power, given this will be running 24/7, and that this computer will be located in the northeastern US where electricity is ~$0.43/kWh
  • Supports at least 4 sata 3.5" drives (via a drive dock over USBC is ok)
  • Supports either 2.5G ethernet or has at least one PCIe slot I can use for a NIC
  • Has 16GB or more of RAM (6GB for the desktop, 10G or more for the services)
  • Has at least 10 threads (4 for the desktop, 6 or more for the services)
  • The CPU Has a Geekbench single thread score of >1800, and ideally 2000 or more. I want an upgrade, not a downgrade!
  • Must be able to run Linux & Virtualization (No Zen 1)
  • Total Mobo+CPU+Air cooler+RAM(+sata dock*) under $500 hard limit, ideally under $250. Used is fine.
  • Silent or near-silent
  • New or used, but something new-ish, say within the past 6 years or so (~2018 or later). I have a lot of old stuff from 2005-2011, and that stuff is just too old at this point.
For the transcoding, I assume I can just use an internal GPU, but if not, I would need another pcie slot and a cheap GPU too.
I want to make a system that will last for at least a decade and isn’t immediately ewaste. I have lots of cases, PSUs, HDDs, SSDs, and peripherals, so I do not need recommendations for those. I have looked at N100 style minicomputers, but those seem to have CPUs slower than the current 2008-era computer they use! Most mini PC’s seem to not support that many SATA drives either, though a ut does look like I can plug SATA drives in via a USB-C enclosure, which is fine, though not ideal as then I have to buy a dock too. I see the Ryzen 9xxx chips that launched recently seem ok except for power draw. But this middle zone is where I have no idea what I’m even supposed to be looking for for a good cheap deal.
  • used laptop + SATA dock? sure, are there any models I should look at in particular?
  • used office PC that is big enough to house 4 HDDs? Some of the HP EliteDesk G4 Core 8500 ones I see look like they may be reasonable, though again with a dock, and maybe a bit too much power draw? What other used models should I be looking for?
  • New minipc? Lots of N100 ones seem slow, I see a few 5800U that are a better fit, but obviously way more expensive comparatively
  • NAS chassis? Seem similar to the minipcs, but worse except for drive carrying capacity
  • new Desktop? I worry about power draw and noise, plus I usually am at the $500 limit very quickly
  • used desktop? Somehow the prices seem similar to new
What should I be looking for? Is there some other options that I’m missing? I don’t mind waiting around for a few months for deals or ebay stuff to pop up, but at this point I’m just overwhelmed with all the options and would appreciate guidance.
Thanks in advance
Okay, I am going to be a big bummer here, but you are asking for two things that are orthogonally different in use case.
For the server, the cheap option that could work well is a Raspberry Pi for ~$150 (board is $60 but cables, case et cetera all add up). This one will require a lot of tinkering and know-how on Linux, and would not make a good NAS.
On that note, a Raspberry Pi 400 16GB could possibly be enough for what you want for your parents, if Windows is not a strict requirement:
If you do not have a ton of capacity requirements I would probably get the following.
NAS
Component Model Price
Base Unit Asustor Flashstor 6 $449.00
Storage Teamgroup MP44 4TB m.2 2280 PCIE 4.0 $222.99
Total $894.98
Yes, this NAS is kind of expensive, but it has a low power draw, 6 bays of storage, and require very little tinkering. The only downside is that m.2 capacities are not yet 100% up to where they need to be, so capacity is going to be only 4TB for a mirrored setup, for now. You can get up to 6 drives for a total of 20 TB redundant storage and the flashstor should be decent enough for the background tasks.
Desktop
PCPartPicker Part List
Type Item Price
CPU AMD Ryzen 5 5600GT $125.00
CPU Cooler Noctua NH-L9a-AM4 $44.95
Motherboard MSI B550M PRO-VDH WIFI $89.99
Memory TEAMGROUP T-Create Expert 2x16 GB DDR4-3200 CL16 $49.99
Storage TEAMGROUP MP44L 1 TB M.2-2280 PCIe 4.0 $56.99
Case In Win CJ712 w/265W PSU $97.96
Total $464.88
This is where you save the most money, AM4 is on the way out so there are really great deals to be made here for a “grandma PC”. It is possible to get this below $400 if you go for the most budget of budget builds, but I chose slightly better quality parts.
I personally do not believe you can get any better than this for a budget below $1500. Of course, better is subjective. Feel free to take all that has been said above as a starting point, not the end all be all. :slight_smile:
super easy:
Ryzen 7 or 9 either 7000 or 9000 series
32GB RAM
on a MoBo that supports ECC
Asus has a board that does it all with 2.5 Gb NIC
and…
not a problem…
no
not gonna happen
start looking for a used Dell Precision, HP Z series, Lenovo ThinkServer tower
But at that price point, you are asking the impossible.
Anything cheap with your desired performance will be loud and power hungry
Good, Fast, Cheap: pick 2
$.43/kWh is a bag of hurt. A lot of my builds wind up drawing 100w or so when sitting ready but not doing much of anything. If we roll with that number it’d be $31/mo for 24/7 operation. $371/yr.
$3710 over a ten year life expectancy assuming the price of electricity remains constant.
In cool/cold months the “free” heat emission would help heat the home and defray a small fraction of the cost… But still.
I fear your quest for horsepower and future-proofing might put this build too close to 100w.
Yup, that’s why I’d prefer lower power (wattage)
Ah good terms I can now research, thanks!
Windows isn’t necessary, I’ve been looking at it a bit too, but it always seemed like x86 gave even more bang for buck
I must not have mentioned this, but I already have the storage (sata ssd & hdds, from the previous pc, so I don’t need to or want to upgrade to m.2 per se
Thanks for these thoughts, I know it’s definitely not the easiest spot to look for stuff in.
