Cheap Portable Gaming System (laptop?)
Hi guys,
I built a gaming pc last summer. Its great but it is a HUGE full atx pc with tons of heavy hard drives in it and I cant really take it anywhere. I was thinking of getting a cheap laptop to replace my Inspiron 1525 that is 5 years old and cant really play anything but half-life. I wad also thinking of a a mini itx system though. I just want to play some games away from home and not spend more than $300. I dont need to play them on high settings or anything but I just want to play them.
Thanks in advance,
Nate
P.S.: Games I own
Alien Swarm
BFBC2
Blacklight Retribution
CoD5
CS
CS: Contition Zero
CS:GO
CS: Source
Crysis
Crysis Warhead
Crysis 2
Day of Defeat
Deathmatch Classic
Far Cry 2
Garry's Mod
HL
HL2
HL2 deathmatch
HL2 EP1
HL2 EP2
HL2 Lost coast
HL Deathmatch: Source
HL Blue Shift
HL Opposing Force
HL Source
Just Cause 2
Left 4 Dead
Left 4 Dead 2
Planetside 2
Portal
Portal 2
Ricochet
Star Conflict
TF2
TF Classic
Tribes Ascend
UT3
Doom
Doom II
Final Doom
BF3
NFS Most Wanted
BF1942
Arctic Combat
Halo: Combat Evolved
Halo 2
Arctic Combat
For $300 that can't get you alot right away but what I would do is look for AMD APU laptops and  customize it to reduce the price like get the free stuff (sometimes like 2gb of ram and upgrade later). What I mean is check for cheap AMD APU laptops like on clearance , even if it has 4gb of ram it doesn't matter ; why? Well, when you get it check how much ram it can handle and buy some , then buy a ssd for example  a samsung 256gb. That's pretty much what you can do if you want a decent laptop buy cheap and upgrade (keep in mind the support on the motherboard as well as the gpu on board)
Here is a nice one for the price.
Might come with a few scratches but it should be able to handle most of those games.
http://www.newegg.com/Product/Product.aspx?Item=N82E16834231020
p.s.
buy it quickly if your going to get it because once this one is sold chances are they wont have another.
Its a bit out of my price range but how do you thin this laptop will do with games like BF3?
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7551395&CatId=4935
I dont really want a referbished laptop though. I have had bad experinced with referbished electronics in the past.
From what I see online ppl seem to play BFBC 2 and BO2 here's a link :
https://www.youtube.com/results?search_query=AMD+Radeon+7500G&oq=AMD+Radeon+7500G&gs_l=youtube.3..0.2381.2381.0.2468.1.1.0.0.0.0.60.60.1.1.0...0.0...1ac.1.11.youtube.fjIae7kFNMs
https://www.youtube.com/results?q=A6-4455M&um=1&ie=UTF-8&sa=N&tab=w1
There are not a lot of videos on this one. I think I want something with the A8 4500M but cant really find anything cheap. And when I do they are refurbished witch I do not like. If you have a sugestion for another laptop that might be helpful. :)
Found some more but a little higher in price :
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=8176857&SRCCODE=GOOGLEBASE&cm_mmc_o=VRqCjC7BBTkwCjCECjCE
http://shopping.hp.com/en_US/home-office/-/products/Laptops/HP-ENVY/C9W57AV?HP-ENVY-15z-j000-Notebook-PC
http://www.govtechdepot.com/hp-envy-dv7-7234nr-amd-quad-core-a10-4600m-accelerated-processor-2-3-8g-750g-c6p04uar-aba/?ref=lexity&_vs=google&_vm=productsearch
http://www.storeelectronic.info/Smart-Buy-ProBook-4545s-AMD-Quad-Core-A8-4500M-1-90GHz-Notebook-PC-4GB-RAM-500GB-HDD-15-6-LED-backlit-HD-DVD-RW-SuperMulti-Gigabit-Ethernet-802-11b-g-n-7556325
Hey, if you don't anything you like try a local store that might have a sale
