Being in Belgium, I use the Belgian keyboard layout, which is based on the French one.
My problem involves the numerical keys above the regular letters. Unlike qwerty users, we need to use the shift button to get the numbers.
Normal : &é"'(§è!çà
Shift : 1234567890
Caps lock should behave like shift, but it doesn't. I get &É"'(§È!çÀ , which is basically the same as the normal ones but the é, è and à have been capitalized.
I've tried every variant of the Belgian layout and every setting of the caps lock behavior, and keep getting the same incorrect behavior.
Does anyone know a way to make caps lock act like a proper shift lock?
Using the numerical pad on the right is not an option on my laptop, and I have to use said laptop to do a lot of spreadsheet stuff for work.
Switching layouts is too much of an inconvenience, I'd have to do that 50 or more times in a single day then.
