Changing Brightness/Gamma Inside a Windowed Game
Is it possible to to change the brightness/gamma settings per application inside AMD Control center?
I could have sworn when I used to have a GTX 285 it was an option and can't seem to find a similar method for my 280X...
Basically I'm trying to run a game in Windowed and need to increase the brightness.
Thanks for the help guys.
amd drivers are very crappy as far as features go sorry to say CCC dosn't have an option like that at-least not for games. if your game isn't very demanding and you have an intel gpu you could use that. if not you could also use a shader injector like SweetFX to increase the brightness.
