Airclick is/was a USB RF remote for controlling software. It had mostly Mac and some Windows support for specific applications, but nothing for linux.
No problem, someone named Bryan Taylor made a cool airclick linux software that is far more functional: a daemon interprets combinations of single and double presses of the remote’s 5 buttons, with 62 possible input actions, and maps them with a config file to any sequence of keyboard keypresses.
Button combinations
From the README:
For the curious…
This 5 button remote supports many more than 5 button combinations, but just how
many more? We will assume that C(n, r) indicates the number of ways to choose
r elements from a group of n, or rather, the number of possible metabuttons when
you must press exactly r buttons. So, the answer follows:
C(5, 1) + C(5, 2) + C(5, 3) + C(5, 4) + C(5, 5)
5 + 10 + 10 + 5 + 1This equals 31. However, you can single click or double click each of these
button combinations, so we will multiply the total by two.
31 * 2There are 62 recognizable actions provided by this simple 5 button remote when
taking the ability to double click into account.
This means any software’s keyboard shortcuts could be triggered without having to explicitly support individual software. So neat and versatile.
It was great being able to control my music player (clementine) and volume from bed, or across the house. Fun for impressing techy housemates too.
Alas, the airclick software hasn’t been maintained in about a decade. It compiled fine on previous versions of Ubuntu, but now on Fedora 28 it no longer compiles. Presumably due to changing C++ standards.
Not being a C++ programmer it’s not easy to figure out if the errors would be easy to fix.
So, L1Techs, what are your thoughts?
Compile errors
$ make
make all-recursive
make[1]: Entering directory '[DIR]/airclick-0.7.1'
Making all in src
make[2]: Entering directory '[DIR]/airclick-0.7.1/src'
g++ -DHAVE_CONFIG_H -I. -I.. -g -O2 -MT main.o -MD -MP -MF .deps/main.Tpo -c -o main.o main.cpp
In file included from airclick.h:32,
from main.cpp:1:
logger.h:130:5: warning: ‘template<class> class std::auto_ptr’ is deprecated [-Wdeprecated-declarations]
auto_ptr<string_stream_type> m_p_stream_buffer;
In file included from /usr/include/c++/8/memory:80,
from logger.h:10,
from airclick.h:32,
from main.cpp:1:
/usr/include/c++/8/bits/unique_ptr.h:53:28: note: declared here
template<typename> class auto_ptr;
from main.cpp:1:
logger.h: In member function ‘virtual int logger_streambuf<char_type, traits_type>::sync()’:
logger.h:99:29: warning: ‘template<class> class std::auto_ptr’ is deprecated [-Wdeprecated-declarations]
m_p_stream_buffer = auto_ptr<string_stream_type>(new string_stream_type);
from logger.h:10,
from airclick.h:32,
from main.cpp:1:
from main.cpp:1:
logger.h: In member function ‘virtual bool logger_basic_simple_rotation_policy<char_type, traits_type>::rotate(std::basic_ofstream<_CharT, _Traits>&, const string&, const string&, const string&)’:
logger.h:265:13: error: there are no arguments to ‘unlink’ that depend on a template parameter, so a declaration of ‘unlink’ must be available [-fpermissive]
unlink(current_log.c_str());
logger.h:265:13: note: (if you use ‘-fpermissive’, G++ will accept your code, but allowing the use of an undeclared name is deprecated)
main.cpp: In function ‘int main(int, char**)’:
main.cpp:369:19: error: ‘getpid’ was not declared in this scope
pid_t mypid = getpid();
main.cpp:369:19: note: suggested alternative: ‘getpt’
getpt
main.cpp:415:25: error: ‘fork’ was not declared in this scope
if ((proc_pid = fork()) > 0) {
main.cpp:415:25: note: suggested alternative: ‘flock’
flock
from main.cpp:1:
logger.h: In instantiation of ‘bool logger_basic_simple_rotation_policy<char_type, traits_type>::rotate(std::basic_ofstream<_CharT, _Traits>&, const string&, const string&, const string&) [with char_type = char; traits_type = std::char_traits<char>; std::__cxx11::string = std::__cxx11::basic_string<char>]’:
logger.h:248:18: required from here
logger.h:265:19: error: ‘unlink’ was not declared in this scope
logger.h:265:19: note: suggested alternative: ‘uint’
uint
logger.h:293:35: error: invalid conversion from ‘const char*’ to ‘char*’ [-fpermissive]
char *lastdot = rindex(files[i].file.c_str(), '.');
logger.h:309:19: error: ‘unlink’ was not declared in this scope
unlink(files[findex++].file.c_str());
logger.h:309:19: note: suggested alternative: ‘uint’
uint
make[2]: *** [Makefile:230: main.o] Error 1
make[2]: Leaving directory '[DIR]airclick-0.7.1/src'
make[1]: *** [Makefile:223: all-recursive] Error 1
make[1]: Leaving directory '[DIR]/airclick-0.7.1'
make: *** [Makefile:162: all] Error 2
