Might want to check out Nanoxia line ups, for EATX it’s Deep Silence 5/6
Isn’t a reset switch ridiculously easy to make?
AFAIK it’s just some thin wires leading to the specific pins on the motherboard that, when the circuit is connected, instruct the system to power cycle. So a simple momentary switch is all one would need along with some thin gauge wire and a two-pin dupont connector.
I really wish someone would make a similar case, but one that wasn’t just a plain square box.
Phanteks Enthoo series, may be next option. Cases are a bit more characterful… some are UNITS
http://phanteks.com/Enthoo-719.html
Since topic starter didn’t react to his topic for over 2 months.
I suppose he already found a case.
