Case recommendation to fit 7900 XTX TUF
Hi all,
I’ve just recently bought an Asus TUF 7900 XTX gpu and wasn’t expecting it to be this monster of a card that it is.
Now, my issue is that it won’t fit in the case without me destroying the case internals, so I think I’ll have to look for something new.
My needs are the following: case should have at least 3 HDD bays and 2 ODD bays (I still use optical drives, so it’s a must) and it has to have a windowed side panel. Of course, by default the GPU has to fit in it too :slight_smile:
So far I’ve found a couple that won’t bankrupt me, so here are my choices:
Thermaltake Versa N26
Fractal Focus G
bequiet! Pure Base 600 Window (both the full black one and the one with orange stripes)
Thermaltake Versa H26 Tempered Glass
Phanteks Enthoo Pro PH-ES614P BK
Thermaltake Core X31
What do you guys think? What would you recommend besides these? I believe the GPU should fit along with everything else in the case.
I would like to mention that I’m based in Romania so some cases I might not be able to find.
Thanks in advance for the help.
This topic was automatically closed after 273 days. New replies are no longer allowed.
