Capslock and Numlock Indicator Lights on Keychron K10 HE
KVM Model:
SQ8535421
5
Problem:
I have a new keyboard (Keychron K10 HE) and have had a few issues. The first issue was the hotkey switching did not work. I solved that by recompiling firmware to disable NKRO and MOUSEKEY (QMK)
The only issue left is I cannot get the numlock / capslock indicator lights to switch. Functionally the keys work fine so it’s not a huge deal but no clue as to why this would be an issue. I have tried direct connecting to both the HID and non-HID ports. The indicator lights work fine if I direct connect to my PC.
Also, are the manuals available online at all?
The # listed is a SKU, can you list the model# on the bottom of the KVM? Once I have that I can link one.
I’m not too sure regarding this. QMK should work in the HID ports, though. Maybe try a long power cycle of the KVM and see if anything changes?
PAAG-E3112B
So I tried disconnecting all powered USB + the actual power of the unit and waited a minute but no change with either the direct connection or the 2.4ghz receiver for the keyboard. If I plug into the front USB port (the right one that is oriented horizontally and not part of the switched input) the indicators work so the keyboard itself can function. Since I had to disable NKRO and MOUSEKEY in the firmware to get the hotkey switching working on the KVM, is there anything else I could maybe do firmware wise that’s preventing the keyboard from seeing the caps/numlock states?
Also just to add.. I’ve had this unit since 2020 and it’s been amazing for my setup and still working perfectly and I’m very happy with it. This is a very minor (but annoying) issue in the grand scheme of things.
