I have spent the better part of two days trying to setup a single GPU passthrough, following many guides including this Rising Prism one.
But no matter what scripts or guide etc I use, I was unable to unbind amdgpu. This is regardless of whether I use modprobe -r amdgpu or virsh nodedev-detach etc.
The ONLY way I have been able to succeed in unbinding amdgpu, is to physically unplug my Display Port cables from the GPU, BEFORE attempting to unbind. Which, ok it works but is incredibly inconvenient, especially with my current setup.
So I ssh in, I unplug my cables, I run sudo virsh start win10, wait for it to succeed, if I VNC in I can see the windows vm etc. Also sudo virsh destory win10 will also hang and never finish unless I unplug my display port cables…
Does anyone have any clue as to what is going on here? How do I even begin to figure out what specifically is causing this issue? Any help would be appreciated.
OS: CachyOS x86_64
Host: MS-7C95 (1.0)
Kernel: Linux 6.19.9-1-cachyos
Display (LS32DG30X): 1920x1080 in 32", 60 Hz [External]
Display (DELL C2422HE): 1920x1080 in 24", 60 Hz [External]
DE: KDE Plasma 6.6.3
WM: KWin (X11)
Terminal: konsole 25.12.3
CPU: AMD Ryzen 5 5600 (12) @ 4.47 GHz
GPU: AMD Radeon RX 6700 XT [Discrete]
Memory: 5.08 GiB / 31.26 GiB (16%)
Swap: 1.64 MiB / 31.26 GiB (0%)
Disk (/): 32.07 GiB / 931.01 GiB (3%) - btrfs
