Can't query AdGuard in a rootless podman container
Hi,
I’ve recently decided to upgrade my home server setup, which included moving from docker to podman. Nothing against docker, but I wanted to try rootless containers and also podman has nice integration with Cockpit.
The problem is that I can’t connect to AdGuard’s DNS. I’ve tested it in rootful mode and it works like it did on docker.
My setup:
I have host Fedora 38 machine with single physical network interface. It runs a VM, also F38, that is my podman machine. On host I’ve created bridge0 with my single physical port as a member, bridge0 is attached to the VM. Both host and guest are accessible on the network with their separate IPs from DHCP. I can SSH into them and access Cockpit. SELinux is set to permissive on both host and guest.
Container is running on the VM:
[mcmonster@esteban adguard]$ podman ps
CONTAINER ID  IMAGE                                 COMMAND               CREATED         STATUS        PORTS        NAMES
1afb03f53af5  docker.io/adguard/adguardhome:latest  --no-check-update...  20 minutes ago  Up 7 minutes  0.0.0.0:53->53/tcp, 0.0.0.0:3000->3000/tcp, 0.0.0.0:8024->80/tcp, 0.0.0.0:53->53/udp  adguard
VM itself is listening
[mcmonster@esteban adguard]$ netstat -tunlp |grep rootless
tcp6       0      0 :::8024                 :::*                    LISTEN      7468/rootlessport
tcp6       0      0 :::3000                 :::*                    LISTEN      7468/rootlessport
tcp6       0      0 :::53                   :::*                    LISTEN      7468/rootlessport
udp6       0      0 :::53                   :::*                                7468/rootlessport
Firewall allows DNS (both TCP and UDP)
[mcmonster@esteban adguard]$ sudo firewall-cmd --list-services
cockpit custom--8024 custom--81 custom--hbci dhcpv6-client dns http https ssh
Ports are open on the firewall as seen from my desktop PC:
$ nmap -p 8024,53 10.0.0.4
PORT     STATE SERVICE
53/tcp   open  domain
8024/tcp open  unknown
The container itself has network and is listening:
/opt/adguardhome/work # ip a
2: eth0@if4: <BROADCAST,MULTICAST,UP,LOWER_UP,M-DOWN> mtu 1500 qdisc noqueue state UP qlen 1000
    link/ether 72:93:9a:9b:05:7d brd ff:ff:ff:ff:ff:ff
    inet 10.88.0.3/16 brd 10.88.255.255 scope global eth0
       valid_lft forever preferred_lft forever
    inet6 fe80::7093:9aff:fe9b:57d/64 scope link
/opt/adguardhome/work # netstat -tunlp
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 :::80                   :::*                    LISTEN      1/AdGuardHome
tcp        0      0 :::53                   :::*                    LISTEN      1/AdGuardHome
udp        0      0 :::53                   :::*                                1/AdGuardHome
Network backend on VM is netavark:
[mcmonster@esteban adguard]$ LANG=C sudo podman info --format {{.Host.NetworkBackend}}
netavark
And the container is connected to preexisting podman network:
[mcmonster@esteban adguard]$ podman network ls
NETWORK ID    NAME             DRIVER
f2783b4e4f73  adguard_default  bridge
2f259bab93aa  podman           bridge
I can open management interface on redirected port and AdGuard is running:
$ curl 10.0.0.4:8024
<a href="/login.html">Found</a>.
But I can’t query the DNS:
$ nslookup kernel.org 10.0.0.4
;; communications error to 10.0.0.4#53: timed out
Can’t do it even from within the container:
/opt/adguardhome/work # nslookup kernel.org localhost
;; connection timed out; no servers could be reached
Server:         10.0.0.1
Address:        10.0.0.1:53
Where’s the problem? What am I missing?
dunno if this applies to podman itself, but using ports under 1000/1024(dunno which is correct) requires root/sudo privileges so far. hope some1 can prove me wrong for this and may help you better as me.
Forgot to mention it in the original post. You are correct, but it’s configurable on the podman host:
[mcmonster@esteban adguard]$ sudo sysctl net.ipv4.ip_unprivileged_port_start
net.ipv4.ip_unprivileged_port_start = 50
Without this the container would fail to start at all.
In the meantime I’ve found a possible solution using macvlans (can’t post a link). I’m too tired today, but will check that in the coming days and let you know.
Let me answer myself. There’s nothing wrong in podman. Or AdGuard (almost). It was a simple case of PEBKAC.
AdGuard has a feature to allow queries only from specific IP ranges. I forgot that I used it in the first place and changed adressing scheme in my home server when rebuilding it.
The only complaint I have for AdGuard is that it won’t say in the logs that disallowed client is trying to make queries.
