Cant Get ram to run higher than 1333MHz
I just got my new rig set up and cant get my Kingston hyperx 2400MHz ram to go any higher than 1333. I have also tried my crucial ballistix 1866 ram from my main rig I got the same result. I have tried every frequency between 2400 and 1333 every one comes up with a overclock error. The ram is for my apu build so it is very important that I get some faster clocks. Do you think it is the ram, or motherboard? Or maybe I am doing something wrong in the bios. Thanks for your help!
Cpu a10 6800k
mb gigabyte GA-F2A85XN-WIFI
psu silverstone st455f 450w
How are you getting these numbers? BIOS or hardware checking program.
Just going to post this because I feel it is step one towards a solution.
"The DDR part of DDR3 means 'Double Data Rate'. Meaning that it can effectively do 2 times the work per clock. RAM is most often referred to by its effective speed in this case 1600MHz which is twice that of its "real" speed which is 800Mhz. CPU-Z just reports the real speed. Your RAM is functioning perfectly fine.
As to Faster but Less RAM for gaming, from what I have read Intel's RAM controller is really good and the speed of RAM has little effect on performance."
http://www.tomshardware.com/forum/306685-30-1600-runs-800mhz-p8p67
https://teksyndicate.com/forum/build-pc/cant-get-ram-run-higher-1333mhz/155884
Been solved already.
Is it just me or have double posts gotten worse lately?
