so, like the title says, i can't get eyefinity to work with my 6850. I have been researching this for over 20 hours trying to get this to work. So, i think it's possible to do, correct me if i'm wrong though. I have gotten the active display port to hdmi cord. i just can't seem to get it to work no matter what i do in CCC.
are you using one hdmi one dvi and displayport? or two dvi and a display port? I tried on my friends and you cant use the hdmi and both dvi ports at once. But what version of amd drivers are you on? you should be able to set up an eyefinity group in ccc
try to go for the 3 monitor setup ?? your goin to need a video card that supports that or it a pain in the ass. i have two 660 and it wasn't just not happening. although their are nvidia card that software is nearly identical.
I updated the Drivers yesterday, the adapter i'm using is display port to hdmi. http://gyazo.com/e2878865836cc8ca2ed733c52401a373 there's me trying to create the group in CCC.
http://gyazo.com/3a62a02c04393498b14ad769ec3fa0d4 i can't seem to be able to enable the third monitor. Thanks for the responses, and sorry i couldn't reply very fast.
