Hi,
I have an old flatscreen monitor from the 2000s that I want to connect to my mini PC that I want to use for diagnostics/monitoring purposes. I purchased an HDMI to VGA adaptor for it as my Lenovo M920Q mini PC doesn’t have a VGA port (it has a VGA port card that plugs into the internal PCIe slot but I replaced that with a 4xEthernet card), but the monitor never detects a video output.
My OS: latest Arch Linux with Hyprland
I tried to list the available monitors to see if it’s being detected by the OS, both with the monitor plugged in and only with the HDMI-VGA adapter plugged in, via Hyprland’s hyprctl list monitors command, but they don’t appear.
Is it related to Arch Linux/Hyprland? Should I try with a different OS? Or is it related to the adapter? One guess I’ve heard is that most VGA adapters can’t supply enough power. I just went with the cheapest Amazon option.
Thanks.
The only thing I can think of is if that is a PASSIVE adapter rather than an ACTIVE adapter.
Not sure this is OS related but maybe somebody else has better insights on this matter.
I think that might be the issue. I just checked some other adaptor type products out there and some of them have a 5V DC input port. I’ll buy one of these and see if it works. Thanks.
I ran into something similar when replacing a workstation connected to a legacy video matrix. The original workstation used a DVI-I to VGA adapter, and the replacement used DisplayPort to VGA. The issue was ultimately solved by using an adapter with an active chip that synthesizes the analog signal from scratch.
The DVI-I adapter worked passively because DVI-I carries both digital and analog signals. The analog pins are essentially the VGA signal already, so they route straight through without any conversion. Most adapters that should work will be labeled “active” and have a built-in converter chip that draws power either via USB or from the port itself to generate the analog signal.
