Hello forum.
So I'm building a gaming PC http://www.ebuyer.com/lists/list/164833
Can you help me, i'm not sure about the graphics card, I would be going crossfire with it. Is it a good idea or should i buy just buy one 7970?
I think everything else on the list is okay.
Please tell me what you think, if its good, if an item is bad or doesnt fit, thanks.
it's better to get a single, more powerful card than to get 2 lower-end ones. not all games support xfire
Okay, would you be so kind to suggest a card?
How much money are you willing to spend for your GPU? Anything above $380 my best bet would be to go Nvidia. Anything under $300 I would suggest AMD.
$400 Nvidia> http://www.newegg.com/Product/Product.aspx?Item=N82E16814127685
$550 Nvidia> http://www.newegg.com/Product/Product.aspx?Item=N82E16814121634
AMD is very easy to OC GPU's with. AMD Control pannel is super simple. I'm using a 7870 right now OC to about 1150 Mhz with ease staying at a good 50-55 C under heavy load at 50% fan power, never gone over 60 C. I don't know how Nvidia OCing works as I have only been using AMD GPU's so far.
$250 AMD> http://www.newegg.com/Product/Product.aspx?Item=N82E16814150605
$400 AMD> http://www.newegg.com/Product/Product.aspx?Item=N82E16814127732
