CAD Computer
I have been looking to build a pc, I have been going back and forth on a few builds.  I am a student studying to do CAD as my full time job.  I need a pc that I can do work from at home.  I am also a pc gaming.  For this build i need everything, minus a case and a mouse.  This build needs to be capable of running up to 3 monitors, going 2 way sli, and offer a modular power supply.  The part where this gets weird for me is budget  I would like to stay at $2000 or below.  Keep in mind I want windows 8 and i need Pro for some of my programs.  I want a 27in monitor and Astro's A40's.  I will only be gaming at 1080p, but need powerful gpus for rendering and stress testing.  I have a idea of what I want in this build, I have a plan that I'm looking at and looking for help to see if there is anyway I could drop budget some to get it built sooner.  http://pcpartpicker.com/p/1Ndev  Please and thank you
I'm not knowledgeable enough in workstation cards to say how much of a difference this would make but I am aware of the fact that products like the AMD Firepro and Geforce Quadro are specifically designed for CAD and CAD like programs.
I know Quadro and Firepro are designed for it but they suck at gaming, and this build is intended for gaming but I also will need it for work some days.
http://pcpartpicker.com/p/1Ne76
I think an i7 would be better for a gaming and workstation build on a budget
dem astros, and the 770, are combined, 1/3 of the price of your build
http://pcpartpicker.com/user/Commissar/saved/2yrV
Nvidia is just a budget hog in this case. CAD software doesn't use CUDA, but they do generally use openCL for ray tracing and rendering. most of the load from CAD software is on the CPU, so getting a 12 thread cpu should help alot.
The reason I have a E3-1230v2 in the build is that i was told its a i7 with out intergrated grapics and i dont think you can overclock it, which im not very interested in.  I might be wrong, and if I am please correct me.
corect on all points. now, that's just 1155, and 1150 xeons. the other xeons are all quite a bit different....
Commissar, I was origonally looking at the i7-4930k but the price difference of $300 just for the processor alone is alot, I was leading towards Nvidia for the graphics since I have alot of friends who run their cards and love them.
you can also go with the xeon if you want. won't make a huge difference if your projects are extremely complex.
the 770 though, that was really eating up the budget. it made up 1/4 of the cost alone. it's not going to perform any better for CAD or gaming than the 280x...
I will say I'm interested in the 280x but its a bit new for me to say yes or no, I would like to see some more benchmarks on it, mainly using 2 of them, i know they did one on the youtube channel, but it wasent true 100% test.  Im not countng them out yet, but is just to soon for me to say.
they're really just 7970ghz with a few features added on, and maybe a higher clock. unless you're running eyefinity, there's no real reason to go with crossfire, and even then, by the time you are adding a second card, the drivers will certainly have been tweaked considerably.
I made some revisions to the build after talking to you, I changed it to a 7970, possibly a r9 280x in the future but for now its 7970 for the moment being.  I have decide on getting the astros later.  I have a headset that will work but its getting old.  http://pcpartpicker.com/p/1Ng0I
