I’ve started working on a Chip-8 emulator in C++ for practice, and it seemed obvious to me to use uint8_t to represent the 8-bit bytes in the system. However, reading through stuff online, I found that everyone seems to use char for 8-bit bytes. This seems odd to me for two reasons:
It’s a bit counter-intuitive to use “char” to refer to something that isn’t meant to represent characters, not to mention uint8_t would make for more clearly self-documenting code because it communicates intent
I think I recall reading that the size of char is implementation-defined, so it might not even be 8 bits at all
But given that the use of char for this purpose is so widespread and seemingly idiomatic for C++, am I just being stupid here?
I would use uint8_t as well. In practice it doesn’t make any difference, but it shows your intent better than char. I really don’t use char for anything anymore. It’s obviously not suited for characters and if I need fixed width integers the cstdint header has them all.
That’s reassuring. I have a follow up question:
In the emulator I need to read some binary data into “memory”, and what I thought of doing was something like this:
std::array<uint8_t, 4096> memory;
std::ifstream ifs {path-to-file};
// load file into memory starting at 0x200
auto mem_it {memory.begin() + 512};
std::copy(std::istreambuf_iterator<char>(ifs),
std::istreambuf_iterator<char>(),
mem_it);
This seems to work, but the the use of char is unfortunate, and replacing it with uint8_t makes the compiler complain about no known conversion from std::basic_ifstream<char> to std::basic_streambuf<unsigned char, std::char_traits<unsigned char> >*.Is there some obvious way of using uint8_t as the type parameter to std::istreambuf_iterator that I’m missing here, or am I just going to have to live with the char?
Thanks! That got the code to compile with uint8_t. It’s curious though, that when I tried to write back out to disk using a basic_ofstream<uint8_t>, I got a bad_cast exception from the stream constructor. It kind of seems like the STL really doesn’t want to let go of char. I don’t suppose there’s yet another thing I’m missing here?
Edit: hurrrrr
The bad_cast wasn’t coming from the constructor to basic_ofstream, it was coming from
Either way I’m kind of getting the impression that the STL insists on doing characterwise IO, rather than letting me insist on 8-bit bytewise IO. Maybe I’ll look and see if there’s something in C that I can use.
As long as you keep the types the same there shouldn’t be any issues. And I would recommend trying to stick with STL, because when you learn it, its so much more powerful than just using C functions.
A cursory look at C didn’t yield anything that seemed sensible in this case. It seems like char and byte being synonymous is just how C++ is after all. I don’t like it, but I guess it works. I ended up using normal fstreams in the end after all. Thanks again for all the help.
