I'm setting up my first pc and I'm having problem choosing which parts should I go with. About the ram I chose(see below) - there isn't much difference in price to 8gb 1866,1600 and i had my reasons. And I chose Gigabyte mobo's because i read a lot of people saying they're good and durable. Btw the parts here in Philippines are limited so there isn't that much to choose from. Also for some reason i like amd gpu's and i don't know why! Sorry for my bad English.
GPU: Sapphire 270x, I'd go for a 270 though, you can overclock it almost equal to the 270x for cheaper.
Mobo: I wouldn't go Gigabyte, I had 2 DOA's in a row when I built a pc a couple years ago. The AsRock 970 extreme3 is awesome if you can find it, they're pretty cheap too. If it's your first computer then you probably don't need a 990fx unless you're comfortable with overclocking.
@NoobCondiment The only r9 270 I found is the msi r9 270 twin frozer gaming 2gd5 battlefield 4, and I'm going to overclock the fx6300 when i saved more money to buy a good cpu cooler.
@Some Tech Noob there's a Asus M5A99fx Pro r2.0 but it cost P7,400 about $165. I I think I'll go with ga-990fxa-ud3 since I also read some of your suggestions and other people in other topics that gigabyte is a good mobo. Also I'll go with your suggestion about sapphire vapor-x- 270x and seasonic. Thanks a lot for your suggestions.
