Hello Members I need you help me on choosing the hardware needed for this overkill Router/Modem but I need the following.
-Needs to handle Website Filtering,Heavy Load, etc
-Need an ADSL and a Fiber port
-Needs 802.11ac access point and atleast 4 ethernet ports
So if you have any advice it will be much appreciated, Thanks BeauTheWinner
Why do you need a fibre port? Rather than an adsl port what you need is atleast two Ethernet ports, one for WAN and one for each LAN you want (probably just one unless you want to separate your network) then get an adsl modem, put it in bridge mode and connect it to the WAN port.
As for hardware unless you're worried about power consumption than pretty much any desktop hardware will be able to handle what you want. If you're using Pfsense for the OS there is a hardware guide on their website.
Wireless on Pfsense is pretty hit or miss and it doesn't support AC so just grab a router or access point and connect it to the LAN port of the Pfsense box
You would be better off to do these things separately. For example:
Modem <=> Router <=> Switch and access
Use your modem just as a modem and use it only to pass info to the router.
Your router will then take care of all network services, like packet filtering, port forwarding etc
Then have access separate. like using a switch and an access point.
This way is better as your modem will take your ISPs connection type and relay the packets over ethernet to the router. So say you switch ISPs or move to another area where the connection is different, you only have to switch the modem out.
As for using an access layer instead of multiple ports on the router (side note modem/routers with multiple ports are referenced as having an inbuilt switch) as each NIC on a router acts an independent network. So thus they can't share IP subnets and you have to setup connections within the router to accommodate packet redirection between subnets. (so say you have a file server on one and your computer on another, you have to set the router to allow that connection). This is great if you have servers that are being accessed from the WAN and you do not want to risk potential access to your personal machines.
Also as Dexter says. pfsense is a bit iffy with wireless support, so you would be best to use a separate access point.
As for the fibre.... is this for WAN or LAN. As on the WAN that would be taken care via the modem and on the LAN you can either use a Fibre card in the router (to say connect to a switch) or use Fibre from a switch capable of that.
