I often want to make food or cocktails in the kitchen, and I either just put my phone on the counter and get it dirty/sticky or print out a recipe
Neither of these are very handy. So I decided to build a PC with a touchscreen that I could place in the kitchen and view recipes on
Luckily, I have a self hosted instance of Mealie I keep my recipes in, and it has quite a good UI. I have a few spare Pi’s which I wanted to use, but I found touchscreens for them are expensive and generally low quality
But, I realized I have an old ThinkPad X1 Carbon collecting dust. Its old, and the screen hinge is not in the best of shape. So my plan is to get this setup as a sort of Kiosk PC in the kitchen in a custom frame/enclosure. Its an i7 3667U with 8GB of RAM and a 256GB M.2 SSD
Here are details and where I am, and what I still need to do
Here is a Demo of where we are at right now
- Installed Pop_OS (Why? It seemed to work well with laptops)
- Enabled SSH so I can remotely manage it
- Set the account to Autologin
- Set Firefox to start on login and go to the Mealie instance
- Installed ForceFull on Firefox so it goes full screen automatically
- Set it with the lowest power more, and not to go to sleep
And the long list of things to do
- Confirm idle power usage. Right now it seems to be a little high. It may be spiking up to try charge the old battery?
Possibly remove the battery. But, if I do I need to make sure its UPS backed. So possible PoE powered? Getting 20v out might be tough though
Figure out passive cooling. In a custom enclosure I should be able to passively cool it
Figured out how to disable pinch to zoom in Firefox. It can really mess it up, and getting it back to 100% is tough
Make VNC available on boot. VNC seems a little weird in Pop_OS
Possibly make the OS read only?
Find a way to go back and forward easily. Swiping left and right does not work
Fix this issue where swiping down to get the address bar exits full screen (Also happens with Kiosk mode)
- Fix an issue where the cursor lands on the edge of a recipe and ends up causing a flickering address in the bottom left
Would love any comments and input
