Building a SFF PC
Dear Very Nice Leve1Techs inhabitants,
I am trying to put together a build for a SFF PC. It’s for my mother, and will only be used for office-type things + Zoom etc., but I want it to be extremely future-proof and reliable (she uses stock Fedora/Gnome and e.g. the GPU requirements are creeping upwards over time).
It has to sit on top of her desk and not take up too much room or be too noisy. I already have CPU/memory leftover from a previous upgrade, and storage will just be a 2.5’ SATA SSD from her current computer (which is a great big hulking full tower ATX thing that I built c. 2012).
Here’s what I’ve come up with already: PC Partpicker list
I’d quite like to keep the cost <£300. I’ve built a few PCs before but never SFF. I suppose what I’m competing with are those cheap micro-PCs from AliExpress, or high-end Raspberry Pis etc., I’m just a bit skeptical about their reliablity/future-proof-ness.
Thanks for any suggestions.
I would have considered an APU like the 5600G/5700G. Maybe an asrock deskmeet.
Yes if I had a leftover 5600G that would’ve been ideal. Maybe I should opt for a second-hand RX 570 from ebay instead.
The A520 chipset is limited to Pcie 3.0. The RX6500XT is a Pcie 4.0 x4 card and would be bottlenecked by the Pcie 3.0 slot.
Oh very interesting about the Deskmeet. I didn’t think you could still get that style of ‘barebones’ kit.
Ok possible alternative part list:
  • ASRock DeskMeet X300 (£216, Amazon)
  • Second-hand RX 570 4 GB (£50-ish?, eBay)
  • CPU/RAM/SSD already obtained
Much cheaper!!
Not sure what the Deskmeet is going for now. It might cost more than building your own now. It was once a good option.
Oh but I’d still need a CPU cooler I assume?
And would a discrete GPU be too large for the (even smaller/cheaper) DeskMini X300…?
Deskmeet x300
Up to 54mm heatsink so the nocuta will fit.
Up to 200MM GPU.
It’s Pcie 3.0 so the 6500xt would be bottlenecked.
In this “high end office” application, I’d say it is fine.
Hmmm… The 6500 XT isn’t really a good value these days. I’d say do this instead if you want to downsize:
PCPartPicker Part List
Type Item Price
CPU AMD Ryzen 5 5500GT £107.95
CPU Cooler Noctua NH-L9a-AM4 £39.95
Motherboard ASRock A520M-ITX/ac £91.98
Memory Corsair Vengeance LPX 2x16 GB DDR4-3200 CL16 Purchased
Storage Solidigm P41 Plus 500 GB M.2-2280 PCIe 4.0 £47.21
Case CiT MTX-007B w/180W PSU £47.31
Total £334.40
Same budget, much smaller case. You do lose some performance with the graphics, however - but you get a lower power system overall.
Getting an old AMD GPU from eBay doesn’t satisfy the “extremely reliable” requirement, imo.
I’d suggest getting an Arc A380. Better media engine than AMD, great Linux support, gaming perf is worse than AMD but that is a non-issue for you.
Given the budget, requirements, and use case I wouldn’t even bother about a GPU, it wouldn’t be reliable.
With your RAM an APU would be good, but it may not be as fast as you’d like it and might need an overclock on it and the RAM, which wouldn’t be as reliable as you may hope either (though in my experience, it should be fine and won’t crash if you don’t go crazy).
If you have to get a GPU, you could get an RX480. 8GB for the Google office suite is near-overkill, even 4GB is more than enough if you get that model. They go for around £50 on Ebay.
1060Ti’s go for around the £50 range too.
To keep it in budget, I wouldn’t say Intel Arc is an option, since they’re relatively too new to have their price dropped. Looking on Ebay, people still want £150 for an A380, and Intel Arc on Fedora is annoying as anything, speaking from experience.
They’re trying to re-use a 5600X CPU, so they need a GPU.
