So Im building a new pc and would appreciate some help choosing the parts. Ive copied the format as best I can. If you need any other info let me know.
To make things easier around here just include some extra info so we can tailor you better.
- Budget. How much are you willing to spend? £1400
- Where do you live (what country), and what currency do you use? UK, GBP (£)
- -Is there a retailer you prefer? No
- Do you need or already have peripherals? I need a monitor, mouse, keyboard and headset
- What will you be using your future computer for? Gaming? Rendering? Mix of both? Or is this a home media PC? Gaming
- Do you overclock or want to get into overclocking? Yes
- Do you plan on going for custom watercooling now, or in the future? Most likely not
- OS. Do you need a new one? Yes
If you Game-
- What kind of settings do you like or what FPS do you want to play at? As high as possible for my budget
- What resolution will you be playing at? Whatever you recommend
- What kind of games do you like to play? Mostly shooters (Battlefield etc) but play many other styles too
If you don't have peripherals -
- What kind of keyboard do you prefer? Mechanical
- What type of mouse-grip do you have? Palm
- What kind of games do you play? Mostly fps, I don't like too many buttons
- What size monitor are you looking for, and what resolution? Size either 24 or 27 inch, and whatever you recommend for the other things
Other Notes -
- What is your general experience in building computers? Is this your first build or are you seasoned and just looking for advice? This is my first build
- I'd like for the build to be easily upgradable if I choose to do so in the future
Any help is appreciated thanks!
