- Budget. How much are you willing to spend? Maybe About 400/500 but depends on what recommend i could go more or less
- Where do you live (what country), and what currency do you use? UK (England) and GBP (£)
- What will you be using your future computer for? Gaming? Rendering? Mix of both? Or is this a home media PC? Mainly a portable LAN PC to take to gaming events/tournaments and just friends houses.
- Do you overclock or want to get into overclocking? Maybe but i have someone who could overclock for me but not essential if not needed
- Do you plan on going for custom watercooling now, or in the future? answer same as above
- OS. Do you need a new one? No
Parts already acquired: Nvidia GTX 770, 8GB Hyper X-Fury RAM, 250GB SSD
Note: Been looking at a BitFenix Prodigy Case but unsure if i can get everything to fit. or just would like a case that is easy to carry around.
Highest Game i would like to run would be ARMA 3 / Battlefield 4 (Possibly) but not at the highest settings, if i can play this on the lowest settings i am happy.
I am really useless on parts for this PC - Need Help! :(
- Solzerian
